| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47824 07/18/2005 8:05 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Just did a search, and didn't find what I have seen before, I have the Rochester B 1bl carb, and it starts and runs good, but seems that it's running a little rich..Looked in my manual, and it was saying to turn in the adjustment, and back out 1 1/2 -2 1/2 turns..Really don't want to do that..My question..should I turn it in until it starts to stall, and back it off, or should I turn it until I get the best idle speed? Thanks | | |
#47825 07/18/2005 8:18 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | are you speaking of the idle on the carb? because you stated you did not want to mess with,,,, if it is running like you want it to I would not mess with it, I did increase my idle about 250 rpm to about 800, seems to like it better their,,go google for this site ,Recarbco, I have trouble with the copy and paste,,,it is a good site with a lot of good carb tips. I got mine re-done by them about 2yrs ago,,see ya........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#47826 07/18/2005 8:34 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks Fred..Already went outside and messed with it..Have adjusted idle speed before, and usually keep mine about 800rpm, but was messing with the air/fuel adjustment, because it seemed like it was running a little rich..Hope I didn't screw it up, but seems to be running OK..Guess it's time for a test drive..Later, Steve | | |
#47827 07/18/2005 8:37 PM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | You run the fuel/air screw in till it stops then back it out 1 1/2 turns then start the engine and turn the screw in and out about 1/2 turn at a time to get the best idle then leave it alone. | | |
#47828 07/18/2005 8:46 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks V6, that's what I need to know, Steve | | |
#47829 07/18/2005 10:10 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I adjust it by turning it in slowly till the engine starts to slow down than back it out till it smooths out usually about 1/2 turn. That is the idle mixture. if it is too rich running down the road check the float level. You may have to go to a leaner main jet. On my 235 I run a .055 jet. It had a .053 but was a little lean. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#47830 07/18/2005 10:33 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks, it runs good, but the exhaust pipe is black, and it smells rich..The carb is a bebuilt and have never had a problem, just wanted to save a little mpg..Steve | | |
#47831 07/19/2005 3:59 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | My exhaust is a little sooty too. I'm running a .054 Jet. I'm in the Mile High City so should I put a leaner jet it it. Shooper, do you know what jet size your running? What's the altitude there? That may be a factor. | | |
#47832 07/19/2005 2:17 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are other things that can go wrong inside that carb. Running rich will carbon up your valves and you don't want that. There is a power piston inside that allows more fuel flow when the throttle opens and the vacuum is lowered. If that hangs up, you can have a rich mixture problem. | | |
