2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#476924 11/30/2008 9:09 PM
I just got a new wiring harness from CLASSIC TRUCKS for 47-54 chevy truck. I have never installed a full wiring harness be for . I would appreciate any tips,or HELP!!
Slickt
Always a little scary the first time. Read the instructions a few times. Plan your wire routing to miss moving parts and hot spots. Use grommets when passing thru metal, make sure you get good grounding everywhere. If you have crimp-on connections take your time and make sure they are solid. Any splices you make, I would solder them, and use heat-shrink tubing to waterproof. Once you get going its not that hard.
1940 Chevy KC 1/2-Ton
Yup what Bruce said and try this also, get out the instructions and lay out the harness around the truck on the floor where it all goes to and then stand back and you will get a mental picture of how it lays out in the truck this helps being able to see it instead of the INTIMIDATING box of rolled up wires.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Thanks for the tips !!!!
SliskT
I just finished installing the same thing. If you take your time, it's not that hard. Every wire is numbered, and the directions tell you where to connect each wire. You will probably also need a wiring diagram for your truck. You can find one in your shop manual, or by itself on e-bay for a few bucks.
The hardest part is making sure you have a good path to ground at each device. Grounding wires are not included with the harness. In some cases I made my own.
Dont let the smoke out of the wires. It realy makes for a bad day when the smoke is let out of the wires.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
I haven't let any smoke out out of the wires yet,so I must be doing alright so fare.lol
Thanks again everybody for the help !!!!
SlickT
