3 members (TUTS 59, JeepJoker, Chip O), 96 guests, and 3 robots.
Topics128,035
Posts1,055,447
Members48,422
#474980 11/24/2008 8:22 PM
I saw a show on TV where the hosts used a soda blaster instead of a sand blaster...it seemed easier and safer on the lungs. I was looking at the line that eastwood carries. Has anyone used one of these? Do they work well? What kind of compressor would you recommend that can push that kind of CFM? I have limited blasting experience (only used a friends small blast-it-all cabinet for some small parts) but I would be interested in getting set up with something like this for doing larger projects. I'm looking to remove paint/rust on large parts (specifically a bed, hood and fenders). Any input/experience would be appreciated.
-cale
1951 Chevy 1/2 ton, original 216
http://community.webshots.com/album/568902858IoMdNF
KYFarmTruck #475050 11/25/2008 12:41 AM
It depends on the unit you are referring to. Eastwood states the CFM requirement in each unit's description.
Search this forum on +compressor to find posts with experiences and opinions on different compressors.
I have used the Eastwood 11805 Soda unit (from the original manufacturer for about $250) and it worked great using this compressor (the compressor cost $699 on sale about 1.5 years ago).
Recently, I purchased this conversion kit from Eastwoods and will use it with blaster from Harbor Freight. If need be, I'll get another deadman valve, if the Harbor Freight valve does not hold up.
tclederman #475058 11/25/2008 1:01 AM
be aware that most [or all] paint mfgrs and suppliers will not honor any warranty for their products if used on metal that's been soda blasted .... takes exceptional cleaning to insure all the soda is gone
Flxible #475567 11/26/2008 7:19 AM
Soda gets into everything and is nearly impossible to get rid of. As for your lungs, you should use a supplied air hood with what ever you blast with. If you don't want to fork out the money for a supplied air hood, let someone else do the blasting.
crenwelge #475687 11/26/2008 7:47 PM
Soda does provide benefits over other silicia-based media. To be clear, blasting with silicia based media (like regular sand) is what will kill you. Just using a hood won't help, you actually need a fresh air respirator.
The cheaper option is use media that doesn't have any silicia in it. Be informed, as this is a serious issue--search the internet and read up on articles like this one: http://www.cdc.gov/niosh/silfact1.html
Even if you use non-silicia blast media (like soda), you still need a decent mask for the airborne particles off the metal (paint, oil, grease).
Some people say soda good, some say soda bad, some say you can't sand blast sheet metal, other's say no problem if you don't over do it. It all seems to depend on who is selling what, if you can believe that!
I bought a regular blaster and got some coal slag based media that is ultra-low silicia based. So far I haven't had time to figure out how to get the blaster working enough to say good or bad. I did do some research on safety issues before I tried it.
R-Bo
1966 GMC 305V6 in the family
KYFarmTruck #477526 12/02/2008 5:13 AM
This http://www.alexander-mills.co.uk/sip/compressors/workshop2.jpg
is what I use to run the bigger 110 lb pressure blaster with proper grade coarse garnet and have found that it is easier to clean residue from parts and can be re-used several times unlike soda blast media.
Soda is more suited to surface finishing than heavy duty stripping!
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
doc bob #478588 12/05/2008 3:47 AM
I blasted my frame with industrial quartz (100% silica) and only a nusience dust mask.
eek I wonder how many years I lost.
Moderated by  MNSmith
