0 members (),
146
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | Have a 1955 261 and the oil pan is in bad shape. Has anyone found new pans for the 261. If not what year 235 oil pans will work??
Thanks Eric
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | crowsgmc,You need to know if you have the early 1955 261 or the late 1955 261. If I remember right,the oil pans are different.The early oil pan flanges curves around to straight line(the surface where the gasket is). The later 1955 pan one side curves around and jogs at an angle before it goes straight(the surface where the gasket is).I believe if you got the correct year of 235,it will match the 261 oil pan. Lets see what the experts have to say.
Correct me if i'm wrong . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | Bowtietim, Just looked and the pan has the curved oil pan flange on one side (front right)...seems to be the later model 55 (261)?
Thanks... maybe someone has used a 235 oil pan and can help out. Has anyone been able to find new oil pans for the stovebolts?
Eric | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I'm sure somebody has an nos oil pan,just have to find that person.Post an add it the parts wanted forum,i'm sure you will find a used one quick.Get a hold of wrenchbender on this site,I bet he will have a used one.
Keep in mind the oil pumps are totally different between the two. 1954-early 1955 oil pump = m29 late 1955-1962 oil pump m45 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
