3 members (66flea, BC59, dt235sd),
184
Mod | | | Forums66 Topics128,087 Posts1,056,106 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47683 07/14/2005 4:01 PM | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Anyone out there ever paint their carburetor? I can't say that I recall seeing any that have been painted. I thought since I have mine off to rebuild it, that I might go ahead and paint it. The body seems to be an aluminum casting with an iron casted base adapter.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
#47684 07/14/2005 4:17 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | I wouldn't because any leak will make a mess out of the paint job. While you have it a part take a Dremel and polish it some; will look better in the long run. Plus paint could gum things up, ie. linkage ect. Ben
popcorn The Truth is Out There (I would worry about the Carb holding more heat also. Just my take) | | |
#47685 07/14/2005 4:25 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Eastwoods has a paint/coating for carborators. It comes in silver and gold color. I used the silver on my carbs, it works fine. George | | |
#47686 07/14/2005 5:20 PM | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Originally posted by popcorn3023: Plus paint could gum things up, ie. linkage ect. Ben [Sarcasm On] Yeah Ben, I had the same problem when I painted my doors. Since I didn't mask it, the paint got all over the edge of the glass and made it kinda hard to see out the windows. Not to mention it got all over my door handles. Next time I think I'll just let the doors rust till they fall off. [Sarcasm Off] Seriously, Bob, Like any painting project, I would take measures to not let paint get where it shouldn't, such as on the working parts of the linkage.  I had not thought about retaining heat though. I'll take that into consideration. Thanks for the heads-up. Rance PS: I sure hope you have a sense of humor.
#47687 07/14/2005 5:49 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | PAINT isn't appropriate for a carb, and will gum things up when the gas starts dissolving it Rance, and the heat retention is important - carbs and manifolds work better if cooler - there are special coatings made for carb bodies, if you think you need the show truck look, or you could have it powder coated - the OEM look is a special thing like anodizing, and can usually be regained by cleaning it well, or using the stuff from Eastwood or similar, which is fairly impervious to gas and leaves the carb looking aluminum or the bronzy finish that some have
Bill | | |
#47688 07/14/2005 6:32 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Rance: I guarentee I have a sense of humor; You do not know POP'S to well yet I have to laugh at life!
The heat retention is a big thing, I come from a long back life of drag racing and now my boys dirt track racing. Back in the 60's early 70's we did everything especially the old aluminium foil wrap around gass lines. Ice on intake manifolds anything to get gas colder. Ben
popcorn The Truth is Out There (Tease on I love a good razing) | | |
#47689 07/14/2005 10:20 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sense of humor,,,is that a requirement for posting here,,,,,,,,,,,  Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#47690 07/14/2005 11:21 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | My Carter W-1 was painted black originally and the paint has never been disolved in over seventy years.
Baldy | | |
#47691 07/15/2005 3:59 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I painted one of the numerous carbs that I had on my 302. Used regular engine paint and it held up fine. It is all in the preparation.
Jason
#47692 07/15/2005 9:49 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I used the normal por15 (not the engine paint)for the engine and the carbs. It resists oil and gas and can stand the heat verry well. I alo used it for the carbs. No problem sice years (and I can tell you the paint saw some solid amount of oil and gas :rolleyes: ). But you have to paint them when disasembled, without gaskets and all. Frank | | |
#47693 07/16/2005 4:41 AM | Joined: Jun 2003 Posts: 41 Junior Member | | Junior Member Joined: Jun 2003 Posts: 41 | Rance, Popcorn, Red58, I sure hope you guys don't spread the word that carbs and intakes run better when cooler, what would Tom Langdon, and most of the bolters on this board think. Can you say "mutiny".......haha and I agree with you whole heartedly. Cooler is better. | | |
#47694 07/16/2005 5:54 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Best paint I've used for carb base was appliance epoxy, stands up to the gas, getting hard to find now days in black. Also I've used the silver carb paint from Eastwood, very good stuff. Another pricy option would be to powdercoat, would last for ever. | | |
#47695 07/17/2005 2:35 AM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | JiMerit....bought 2 cans of black yesterday at Ace Hardware...You might give them a try
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
