5 members (Otto Skorzeny, lumbersawyer, BC59, tclederman, 1 invisible), 79 guests, and 1 robot.
Topics128,154
Posts1,056,853
Members48,456
Help
Can you hook up an orgnal Sun tack and Transmiter to the newer HEI dist. Thanks Sam T
k10 Offline
NO. BUT>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
You could send your tach out to a place like http://www.williamsons.com/ and they can convert your old tach. They can make it compatible with 6 or 12 volts, pos or neg ground. You would no longer need the seperate transmitter. And THEN, you could hook it up to any distributor and it would work properly.
K10
Thanks I will do just that. I have installed a 327 in a 58 1/2 ton NAPCO CD Panel, again Thanks Sam T
