NO. BUT>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
You could send your tach out to a place like
http://www.williamsons.com/ and they can convert your old tach. They can make it compatible with 6 or 12 volts, pos or neg ground. You would no longer need the seperate transmitter. And THEN, you could hook it up to any distributor and it would work properly.
