8 members (FAST55, cmayna, jmoore, Gdads51, MickeyP, Biermann, papas52, Otto Skorzeny), 132 guests, and 2 robots.
Topics128,162
Posts1,056,949
Members48,458
Help
Can you hook up an orgnal Sun tack and Transmiter to the newer HEI dist. Thanks Sam T
k10 Offline
NO. BUT>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
You could send your tach out to a place like http://www.williamsons.com/ and they can convert your old tach. They can make it compatible with 6 or 12 volts, pos or neg ground. You would no longer need the seperate transmitter. And THEN, you could hook it up to any distributor and it would work properly.
K10
Thanks I will do just that. I have installed a 327 in a 58 1/2 ton NAPCO CD Panel, again Thanks Sam T
