| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Question for the electrical guru's
My turn signals arent working correctly. If I initial turn the truck on, the turn signals work properly, as I transition from Park to Reverse to Nuetral to Drive, the flashing changes from steady to slow to fast to fast. Once I put it in drive and start moving and try to use the blinker, it flashes once then nothing. And I can change it from either left or right and I will still only get 1 flash then nothing. Also the Emergency blinker works perfectly.
From this point on, the blinker will not work properly no matter what, unless I shut the truck off and start it back up again, and it does this process all over.
I have changed the Turn Signal Switch, I have changed the Brake Light Swtich, these have not fixed the problem.
I assume the problem is a short. Is there anywhere in particular that I should look based on the syptoms?
Thank you | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This site is for '72 and older trucks. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Yep, what Cletis said, but I imagine you didn't know where to put it though and wanted help. I think it would be better to post this down in the Greasy Spoon part, someone there is always willing to help, and it doesn't affect other people trying to get help.  | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Try Chevytalk.com. There is a spot just for your year range of truck. It sounds like maybe the wires have been compromised in the column. When you shift, the power goes to a different lead at each position. Just a guess. Go to the "forums" tab (at top) from here. http://www.chevytalk.org/fusionbb/portal/index.php | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | do you have a multi functional switch? turn, hi/lo, squirter? you have an expensive switch there,, about $300.00 it has about a dozen + wires to it and some terminals and wires may be fried I can't say that's happening to you but it's best to look at the switch. that ain't fun. good luck
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I replaced the Wiring that goes to the switch.
The problem only occurs when I hit the brakes.
Is it a possibility a relay may be bad? How is pressing the brakes causing a short? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | isolate...... look at the brake rod, pedal arm & see if you're pulling a wire and shorting it??
pull fuses and see what circuit is involved. when you pull that fuse and nothing happens at least you found those sets of wires involved. see you're wire diagram.
good luck
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | eraucontroller,
I have a '97 that is loaded with weird electrical do-dads, so I wouldn't be surprised if your '92 has some of the same! What I would check is the taillight assemblies themselves. They are probably plastic housings that require separate grounding which you might be achieving through the filaments of some of the other lamps which would make strange things happen.
I would take each side apart, verify the condition of each little bulb, replacing them if need be, and make sure all the ground wires are clean and secure.
If the plastic housings are bonded to the bed, the bed must be bonded to the frame. It's sort of a long shot, but it will take this question out of the equation. Good luck.
Stuart | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | New information:
Tailight Assembly:
Blinkers are flashing slowly Emergency Lights Work Normally
Reverse Lights dont work Brake Lights dont work
What could cause this? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | your emergency flasher is separate from your turn signal flasher. I would start by replaceing the turn signal flasher with a new heavy duty unit.
Then I would crawl under the truck and follow the wiring, you may have a bad ground in the back.
The reverse lights may be the ground, or they may be a bad reverse switch.
Also, if you have a bulb out the emergency flasher will still flash normally, however the turn signal flasher is not getting enough load to flash.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Ok here is an update*************
I replaced the drivers side circuit board, and all the bulbs and still no success.
Can yall give me some tips as to some good locations where I might find the short? | | | | | Joined: Jan 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 47 | If this has trailer wiring or a hoppy put between the oem connector, remove it and check. Brake light voltage back feeding the turn signal switch is common on this type of add ons. | | |
