0 members (), 110 guests, and 1 robot.
Topics128,196
Posts1,057,394
Members48,471
I would like to lower my 52 pickup about 2" front and back. I know you can lower the front end with dropped spindles but is there another way?
Thanks for any responses.
Ted
illegitimi non carborundum
Mono leaf springs...kinda spendy but look nice and the ride is outstanding
Thruwurkin
Half Ton Will Travel
God bless America...One nation under God
Hey there..Sure love your truck/teardrop setup..Anyway, been through my stack of catalogs, couldn't find a mono-leaf front end setup..Any clues? Thanks, Steve (it's a 54)
Patricks has a kit ,four leafs each side ,new gas shocks ,new bushings and shackles,and for the rear two inch lowering blocks and new u-bolts ,this will lower truck two inches all around ,and improve the ride ,price about $500.00 old navy 51................
shooper, I have the patricks stuff on my 52,,not a bad ride but still stiff if you hit big dips/bumps, and a front axle is still a front axle....Fred
Redryder pix
My Hotrod
Hey Fred..Are the pics of RedRyder what you have now?...Guess I'll get out my Patrick's catalog
You can get your axle droped by mor-drop it is usualy about $400 for a four inch drop. you have to send them an axle so your truck will be down unless you have an extra axle. Go to the parts store and get some 2" lowering blocks and u bolts, and your lowered.with a nice rake.
Can't put lowering blocks on the front can you? Legally or otherwise. Spring is on top of the axle.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Anonymous
Unregistered
Anonymous
Unregistered
Blocks on the rear. IF you could put them on the front, oldblu, is it illegal? Kinda off topic, but could you put the axle on top of the springs? or would you have no travel? Thanks
Junior Member
Junior Member
technically modifying your vehicle from stock is illegal, at least here in california. however you only get written up if you have a rice rocket... cops don't seem to mind our old rust buckets...
I had my stock axle dropped and put lowering blocks in the rear. Putting lowering blocks in the front is dangerous due to the multi-directional force from the steering. Flipping the axle over the springs creates steering problems and only leaves about an inch travel between the axle and the oil pan. Mono leafs or the dropped axle is the best way to go.
Here's a pick of my truck with the dropped axle:
1948 Chevy 3100
Thanks all for the great info. I thought that front lowering blocks was illegal in CA, but what isn't if your not an illegal alien? :confused:
I had considered monosprings, but didn't know of anyone that had tried them on an AD. Now I do and if the ride is good it's worth considering when the time comes. Right now I'm adding power disks to the front and a 605 box for power steering. I'm going to keep the original steering wheel, but lower it toward the dash a little for more 'belly' clearance. I'll post some photos when I'm done. Thanks again for all the great input.
Ted
Look under the front of that '52 and think about how lowering blocks will affect it...
Legal or not, they won't lower the front of a '52 Chevy/GMC 1/2-ton.
