1 members (tclederman),
144
Mod | | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47653 07/13/2005 8:54 PM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | I would like to lower my 52 pickup about 2" front and back. I know you can lower the front end with dropped spindles but is there another way?
Thanks for any responses.
Ted
illegitimi non carborundum
#47654 07/13/2005 9:11 PM | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | Mono leaf springs...kinda spendy but look nice and the ride is outstanding
Thruwurkin
Half Ton Will Travel God bless America...One nation under God
#47655 07/13/2005 9:31 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Hey there..Sure love your truck/teardrop setup..Anyway, been through my stack of catalogs, couldn't find a mono-leaf front end setup..Any clues? Thanks, Steve (it's a 54) | | |
#47656 07/13/2005 9:48 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | Patricks has a kit ,four leafs each side ,new gas shocks ,new bushings and shackles,and for the rear two inch lowering blocks and new u-bolts ,this will lower truck two inches all around ,and improve the ride ,price about $500.00 old navy 51................ | | |
#47657 07/13/2005 10:11 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | shooper, I have the patricks stuff on my 52,,not a bad ride but still stiff if you hit big dips/bumps, and a front axle is still a front axle....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#47658 07/13/2005 10:34 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Hey Fred..Are the pics of RedRyder what you have now?...Guess I'll get out my Patrick's catalog | | |
#47659 07/14/2005 12:47 AM | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | You can get your axle droped by mor-drop it is usualy about $400 for a four inch drop. you have to send them an axle so your truck will be down unless you have an extra axle. Go to the parts store and get some 2" lowering blocks and u bolts, and your lowered.with a nice rake. | | |
#47660 07/14/2005 4:24 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Can't put lowering blocks on the front can you? Legally or otherwise. Spring is on top of the axle. | | |
#47661 07/14/2005 4:29 AM | | Anonymous Unregistered | | Anonymous Unregistered | Blocks on the rear. IF you could put them on the front, oldblu, is it illegal? Kinda off topic, but could you put the axle on top of the springs? or would you have no travel? Thanks | | |
#47662 07/14/2005 4:59 AM | Joined: Feb 2005 Posts: 33 Junior Member | | Junior Member Joined: Feb 2005 Posts: 33 | technically modifying your vehicle from stock is illegal, at least here in california. however you only get written up if you have a rice rocket... cops don't seem to mind our old rust buckets... | | |
#47663 07/14/2005 12:08 PM | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | I had my stock axle dropped and put lowering blocks in the rear. Putting lowering blocks in the front is dangerous due to the multi-directional force from the steering. Flipping the axle over the springs creates steering problems and only leaves about an inch travel between the axle and the oil pan. Mono leafs or the dropped axle is the best way to go. Here's a pick of my truck with the dropped axle: 1948 Chevy 3100 | | |
#47664 07/14/2005 3:49 PM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | Thanks all for the great info. I thought that front lowering blocks was illegal in CA, but what isn't if your not an illegal alien? :confused:
I had considered monosprings, but didn't know of anyone that had tried them on an AD. Now I do and if the ride is good it's worth considering when the time comes. Right now I'm adding power disks to the front and a 605 box for power steering. I'm going to keep the original steering wheel, but lower it toward the dash a little for more 'belly' clearance. I'll post some photos when I'm done. Thanks again for all the great input.
Ted
#47665 07/15/2005 1:48 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Look under the front of that '52 and think about how lowering blocks will affect it...
Legal or not, they won't lower the front of a '52 Chevy/GMC 1/2-ton.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
