| | | Forums66 Topics128,105 Posts1,056,208 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47650 07/13/2005 7:53 PM | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Does anyone have an easy way of adding an electric puller fan to a 57 with a 235? I only have abut 2 inches of space between the radiator and the water pump pulley.
1957 Chevy Stepside 1993 GMC Sonoma
#47651 07/16/2005 5:48 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You could remove the stock fan blade for more clearance and get a good brand electric with a shroud. Set it up to come one with a thermostat, should work fine. Also without the fan you don't need that deep pulley, shorten the pump shaft, switch to a flat pulley and there's your room for the electic unit. | | |
#47652 07/16/2005 9:33 PM | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Ok, thanks. I figured the best bet would be to change the pulley. Do you know of a pulley that would work? Is there a pump that already has a shorter shaft?
