1 members (JeffA),
162
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I am an old Chevy person, but new to this group of vehicles. I recently bought a 66 Suburban with a straight six in it ( 292 according to the build sheet ). It seems to have been a service truck for a private company, and is quite plain. It is pretty much complete and original, but it does not have a Fan Shroud on it. The build sheet also says that it was ordered with the Heavy Duty Radiator, if this makes a differance. I assume that it should have had one, but I have seen no mention, or reproduction units for one. Did the six cylinders have a Shroud, and if so, is it differant from the V8 Shroud? Thank you for your help. | | | | | Joined: Feb 2008 Posts: 17 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 17 | I can't say for sure but the 6 is longer and they both bolt up to the same trannys mounted to the same cross members. They have to be farther forward. The radiators mount the same. So if they use a shroud I'm bettin' it's different.
"I wonder if God created man because he was disappointed in the monkey?" Mark Twain
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | dont know for sure, my 52 half ton did not have one and it never ran hot even here in Tx Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | As far as the older vehicles, you have to remember that up until the late 50's early 60's, the passenger cars did not have shrouds. But I thought after this time period, that they started putting them on everything. | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | i just bought a 65 Chevy Suburban last nite and it has the 250-6 cyl motor and it does have a fan shroud in it, so they did make them for the in line 6-cyl motors. i will try to get a picture of it. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The six and V8 trucks/panels/burbs all had fan shrouds, as least in the 4-5-6 years. The fan shround is sized to the radiator, not the engine. That being said, the swamp cooler (heavy-duty) radiator coupled with the big 6 (292) had the V8 style radiator shroud.
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Thank you for your response. My question now is, even though the build slip calls for a heavy duty radiator, how can I be sure it is still in the vehicle? Is there a number, size, something to look for? I noticed the other day that it is a Harrison Radiator, but is it the original, I'm not sure. Any suggestions? | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | i will measure the rad that is in the burb i just got in and get pictures of it and the shroud so you know what you are looking for. i am not sure where to look for any numbers on it, any ideas 4-5-6 (Tony)?
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Harrison was the factory supplier of radiators in the '60-'66 Chevy trucks and maybe other years, but I am not sure which ones. The large V8 radiator measures 25-1/2" wide x 22-1/2" tall x 3" wide and has HARRISON embossed on the top tank. It sits on the top flange of the radiator cross-member...the smaller six cylinder radiators sit on the lower flange of the radiator cross-member, between the frame rails.
To my knowledge, there are no model numbers embossed on the various radiators...I believe they are idendified by their top & bottom tank size, overall dimensions and number of cores. I did find the following part numbers and applications:
'63-'65 - (230)/Standard transmission Part#: 315560 '63-'66 - (283)/Standard transmission Part#: 3157071/3155062 '63-'66 - (292/327)/Standard transmission Part#: 3155105/3155061 '63-'66 - (230/292/283/327)/Automatic transmission Part#: 3155065
This information is pulled from the "Glenn Mitchell Collision Estimator Inc." "Part Number Service Guide", dated November 1, 1968, specific to the '63-'66 Pick-up, Cab, Panel & Suburban.
