3 members (sron48, Otto Skorzeny, 1 invisible),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 2 New Guy | | New Guy Joined: Nov 2008 Posts: 2 | Hello all, this is my first post... I love your site! So much great info here.
I'm looking at buying a 1971 C50 dump and I'm having some trouble determining the GVW. I actually have not been to see the truck in person yet, I've only seen it in photos and I've talked to the seller via phone. The seller says he can't find a tag anywhere on the truck that lists a GVW. He gave me the VIN, and I called a dealer and had them look it up, but all they could tell me is that the GVW is somewhere in the range of 15k-23k lbs.
I'm going to go see the truck in person and of course I'll look again for the tag listing the GVW, but just wanted to ask here to see if anyone has any other advice for how I might be able to determine the GVW for this truck if the tag is indeed missing.
Maybe I should start by asking, where is the GVW tag typically located in these trucks?
Thanks!!! | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Welcome to the site.
The tag should be on the driver's door jamb on the back side of the cab, at the bottom.
Another way to tell is to see if the sticker is still on the inside of the glove box door. If it doesn't list the GVW, just add the front and rear axel ratings together.
Being a C-50 I'm going to guess it to be at or around 19,500.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Nov 2008 Posts: 2 New Guy | | New Guy Joined: Nov 2008 Posts: 2 | Hi. I have a '71 C-50 dump. It has a tag on the drivers door jam that states the front axle is rated at 7,000 and the rear axle 17,000 so the GVW is 24,000. The tires are 8.25 x 20 on budd rims. Hope this helps.
bagman1957 | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | That is interesting as the trucks that I have seen with a GVW of 24,000 are usually C-60's.
| | | | | Joined: Nov 2008 Posts: 7 New Guy | | New Guy Joined: Nov 2008 Posts: 7 | I would tend to agree with the second post. I have a 69 C-50 and a 67 C-50 and they are both rated at 19,500 lbs. The gross vehicle rating of a vehicle is not necessarily the gross weight ratings of both axles added together.
Rick Woods
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Bagman, I agree with rwoods. The tires/wheels make all the difference on how an axle is rated. C-50's could easily have a 5K front and a 15K rear and be rated as 18K GVWR with small tires. | | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | Mine weighs 8700 on the scale empty. I think the most I ever hauled was 23000. (lime stone gravel) over loaded. | | | | | Joined: Aug 2006 Posts: 20 Apprentice | | Apprentice Joined: Aug 2006 Posts: 20 | welcome, the tag on my drivers door jam on the 67c-40 states a 16000gvw. on the 68c-50 it is 19500gvw.the 67 has a 4000lb front axle and a 13500 rear. my 68 has a 5000lb front and a 15500rear.goodluck! | | | | | Joined: Aug 2006 Posts: 20 Apprentice | | Apprentice Joined: Aug 2006 Posts: 20 | welcome, the tag on my drivers door jam on the 67c-40 states a 16000gvw. on the 68c-50 it is 19500gvw.the 67 has a 4000lb front axle and a 13500 rear. my 68 has a 5000lb front and a 15500rear.goodluck! | | | | | Joined: Jun 2008 Posts: 37 Apprentice | | Apprentice Joined: Jun 2008 Posts: 37 | 66 GM C50 16500 66 GMC 4000 19500 65 GM C80 25000 The first 2, I own. The C80 I just missed out on today  | | | | | Joined: Nov 2008 Posts: 2 New Guy | | New Guy Joined: Nov 2008 Posts: 2 | Thanks to all for your replies. When I went see the truck in person, I did find the tag on the driver's door jam. I was surprised to see that it too gave a range for the GVW. I expected a single number. I decided to pass on buying this truck. It is in OK shape and in case it might be of interest to someone else here, here's the CL listing. (I have no relation to the seller or other interest in this sale). http://boston.craigslist.org/sob/cto/933357900.html | | |
