| | | Forums66 Topics128,096 Posts1,056,473 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 7 New Guy | | New Guy Joined: Nov 2008 Posts: 7 | Would some one please help me with a few simple measurements? I have cut out my firewall and floor from an old rusted out 51 chevy short box 3100 and made a new one with new braces under the new floor, not quite the same as original, I feel the braces are thicker and increasing the cab height. Now 7 years later I have forgotten what the original floor looked like, and now back in the saddle working on the truck again. I would appriciate if someone could give me a few measurements from the front cab mount bracket to the bottom of the floor, (flat floor). Also the rear mount area floor to the top of the frame, and the top of the running board inside lip to the bottom of the rocker panel. This would be greatly appriciated. Carl
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | From the shop manual on this page: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0103.htmFloor panel cross support to frame rail at rear = 49/64” – 53/64” (.765”-.828”) Bottom of floor to top of frame at front mount location = 1 53/64” to 1 57/64” (1.828” – 1.890”) Use your frame as a jig for the other dimensions and make sure the pedal’s won’t rub. There is no set dimension for running board to rocker as a rubber “skirt” hangs down from the rocker to fill the gap. The paint and body forum are your best bet for these questions. Try the search feature for “floor replacement”, “patch panels” or ”cab mounting”.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2008 Posts: 7 New Guy | | New Guy Joined: Nov 2008 Posts: 7 | Thanks for the info, back to work I go. | | |
