3 members (Hotrod Lincoln, mick53, 1955 1 Series), 33 guests, and 6 robots.
Topics128,012
Posts1,055,312
Members48,419
#475706 11/26/2008 9:01 PM
Do you have to cut the outside rubber on the windshield to get it out of the frame on a 1964 chevy pickup?
I saw a tech article somewhere that talked about how to do it on a 1959 truck, but I was wondering if mine were the same.
This article said that you cut around the rubber close to the glass and then just pop it out.
Then to put it back in you put a new seal around the glass with a piece of cord, start it in the frame and while you hold it against the frame you pull the cord, pulling the inside lip of the seal up over the frame edge.
Thanks, Mike
Austin64 #475708 11/26/2008 9:27 PM
Here you go...
It was in the Tech Tips section above.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #475847 11/27/2008 5:05 AM
Mike...The safest way by far to remove your windshield is to cut the rubber.
Laminated glass by nature is quite brittle,especially after 40+ years. Assuming it's original. Even if it isn't you still have to go easy on it.
The tech tip David recommended should point you in the right direction.
Jock.
More pix on Flickr.
