0 members (), 151 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#475562 11/26/2008 6:56 AM
I have 51 chevy 1/2 ton that has a 235 engine with a 4 on the floor. Thing is that I dont want the torque tube because of the fact that is has really low gears and I would to like to change it out for a later model rear end.
Any trans/diff combos that would work fine with the 235? I also have a spare 250 engine with trans(don't know what kind) off of a 79 chevy van. Plus a rear end off of a 1987 chevy truck 1/2 ton.
Would any of these parts work together? ohwell Thanx in advance
I've got a halfton rearend from the late 70's that has 6 lugs and a 3.07:1 ratio, which will allow me to use my 4 speed with moderate hwy cruising speeds. This seems to be a popular pick.
Dave
80's Camaro/Firebird/Nova rears seem to be a popular choice because of width and available ratios.
If you will do a Search (listed at the top of the page) you will find a considerable amount of info on this subject.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
