1 members (Cosmo), 86 guests, and 0 robots.
Topics128,049
Posts1,055,680
#475653 11/26/2008 6:33 PM
If I have a set of 6 volt guages for a 54' 3100, can they be converted to accept 12 volts. Sounds like it must be a simple fix, but electricity and I don't mix.
Yes, the only thing you need is a "runtz" type resistor to go on the gas gauge because it will fry in a hearbeat at 12-volts. The Amp gauge will be fine just make sure you get the right bulbs for the lights also.
Ex Hall Monitor
Ex Hall Monitor
A lot of folks here will tell you that your gauges will fry @ 12 volts but that's not my experience. When I converted my 55.1 panel to 12v years ago I didn't even think about the gauges. I just put a 12v coil, voltage regulator & 12v bulbs in it then put over 100K on it without problems. The gauges never had a problem & worked OK the whole time I owned it. Is that saying you'll never have a problem? Nope, but I never did.
Tiny #475795 11/27/2008 2:33 AM
Yeah, what Tiny says. He's not the only one who just put the 12V to the old gas guage with no problems. It will still read correctly to because of the oposing coils in the guage. Granted, there's a little more current flowing in both coils but the whole thing operates on just a few milliamps (very small amount of current).
