1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 28 New Guy | | New Guy Joined: Jul 2008 Posts: 28 | If I have a set of 6 volt guages for a 54' 3100, can they be converted to accept 12 volts. Sounds like it must be a simple fix, but electricity and I don't mix. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes, the only thing you need is a "runtz" type resistor to go on the gas gauge because it will fry in a hearbeat at 12-volts. The Amp gauge will be fine just make sure you get the right bulbs for the lights also. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A lot of folks here will tell you that your gauges will fry @ 12 volts but that's not my experience. When I converted my 55.1 panel to 12v years ago I didn't even think about the gauges. I just put a 12v coil, voltage regulator & 12v bulbs in it then put over 100K on it without problems. The gauges never had a problem & worked OK the whole time I owned it. Is that saying you'll never have a problem? Nope, but I never did.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yeah, what Tiny says. He's not the only one who just put the 12V to the old gas guage with no problems. It will still read correctly to because of the oposing coils in the guage. Granted, there's a little more current flowing in both coils but the whole thing operates on just a few milliamps (very small amount of current). | | |
