| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | I have 3 questions:
1. What are the advantages/disadvantages of top feed and bottom feed spray guns? (Top feed being guns with the paint canister at the top of the spray gun)
2. What are the advantages/disadvantages of siphon feed vs. pressure feed.
3. What are the advantages/disadvantages of high flow-low pressure guns vs. low pressure high flow? What is considered high fflow and low pressure?
My compressor has max pressure at 120 psi and max flow at 10+ cfm. I have 3/8" hose.
Bob | | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Bob, If you don't get an answer here, check with Len at autobodystore.com He is a great guy with an incredible depth of knowledge about spraying that he freely shares. You can also call him at 609 859 3670. Good luck, Scott | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Due to the VOC limit requirements if you spray much, you will need a HVLP (High Volume Low Pressure) to control air-borne VOC's and not get a fine (your paint shop needs to report all paint sales)
Beyond that, generally pressure guns are for hosing on a lot of paint in a short period of time.
I myself have a variety of siphon guns and will be changing to HVLP's as I replace them.
Scott
| | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | you cant beat a craftsman gun bottom feed thats all i use and ill put it up agaist any gun for any paint work but thats me and it works for me sprays big flakes good to i have one gun thats sprayed over 50 cars not bad for a 100. gun or less on ebay | | |
