1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#474317 11/22/2008 11:51 PM
I have 3 questions:
1. What are the advantages/disadvantages of top feed and bottom feed spray guns? (Top feed being guns with the paint canister at the top of the spray gun)
2. What are the advantages/disadvantages of siphon feed vs. pressure feed.
3. What are the advantages/disadvantages of high flow-low pressure guns vs. low pressure high flow? What is considered high fflow and low pressure?
My compressor has max pressure at 120 psi and max flow at 10+ cfm. I have 3/8" hose.
Bob
JD Bob #474491 11/23/2008 1:12 PM
Bob, If you don't get an answer here, check with Len at autobodystore.com He is a great guy with an incredible depth of knowledge about spraying that he freely shares. You can also call him at 609 859 3670. Good luck, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
Scott54 #475077 11/25/2008 1:28 AM
Due to the VOC limit requirements if you spray much, you will need a HVLP (High Volume Low Pressure) to control air-borne VOC's and not get a fine (your paint shop needs to report all paint sales)
Beyond that, generally pressure guns are for hosing on a lot of paint in a short period of time.
I myself have a variety of siphon guns and will be changing to HVLP's as I replace them.
Scott
you cant beat a craftsman gun bottom feed thats all i use and ill put it up agaist any gun for any paint work but thats me and it works for me sprays big flakes good to i have one gun thats sprayed over 50 cars not bad for a 100. gun or less on ebay
