1 members (Bill Hanlon),
340
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | What would I have to do to get everything registered? It will be a ways away, because I just started the restoration. But I just noticed that the serial number plate is missing. The truck used to be parents truck, but they are transfering the title to me. To get it registered the DMV has to verify that the title matches the serial number on the truck (which is not there) In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | What year truck are we discussing here? Some older titles used the engine number as a means of identification, so it's possible that's what the ID number on the title refers to. If the engine hasn't been swapped out since the truck was new, try looking on the machined pad near the distributor on a 6-cylinder truck, or on the engine block ahead of the passenger's side cylinder on a V-8. (Chevy truck, I presume?) Jerry
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You don't say what year truck. Pre '55 most states used the engine number as the VIN. It is located on a raised boss behind the distributor. If the numbers don't match, the engine has been changed or the serial number (on the missing data plate) was used. If the later is the case you'll need to contact your state DMV for advise on how to rectify the problem.
| | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | it is a 1953 3100. I do not have the original engine. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you can buy a blank # plate http://www.classicparts.com/1953-Door-Post-ID-Plate-Chevrolet/productinfo/33%2D014/ ... for 1953 ... that attaches to the door post and transfer/ punch your # on it. the truck id should be on your title. in most cases you will simply just need the pink or registration paper work to get a license to you. it's that simple.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
