0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#474150 11/22/2008 3:15 PM
Hello, smile
Does anyone know if you can replace the timing gear on the front of the crankshaft, without pulling the crank,or should it be pulled and replaced at a machine shop? headscratchPlease advise.
Thank You
mo2cyl #474176 11/22/2008 4:34 PM
Kevin,
I'm relatively sure you can replace the crank gear without pulling the crank. I guess the problem is that those two gears should be replaced as a pair, and the cam gear is the bugger. Pulling the cam is the only option there.
Stuart
atomarc #474183 11/22/2008 4:55 PM
If your 235 has a fiber camshaft gear and you are replacing it with a fiber gear, I doubt that there is enough wear on the crank gear to warrant replacing it. If you have a aluminum camshaft gear or are replacing a fiber gear with a aluminum gear, I would replace both gears. And yes the crank gear can be replaced without removing the crank.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #474222 11/22/2008 7:11 PM
Thanks for the responses. Got it off this morning, and yes I am going to replace both gears.
Thanks Guys
mo2cyl #474564 11/23/2008 7:18 PM
Most of us heat the new crankshaft gear before installing it. I used the oven to do this.
1951 1 Ton Completed
