5 members (Phak1, Otto Skorzeny, mo2cyl, Greg_H, dt235sd), 87 guests, and 2 robots.
Topics128,049
Posts1,055,546
Members48,425
#474443 11/23/2008 5:12 AM
Hello fellas wave
Ok I got 235 that runs and idles fine but the moment that I step on the gas pedal,it will die out on me. It will crank right up but it will do the same thing. headscratch It seems like the timing is off.
The vacum advance looks original and the moving parts are a little sloppy. I just got the truck and the cap,points and rotor are new. And the gas filter as well. Any tips? Thanx
51_bombtruk #474504 11/23/2008 2:39 PM
You could have a bad accelerator pump. Take the air cleaner off and work the linkage. You should see a squirt of gas. If not the pump is bad, otherwise I have no idea.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #474554 11/23/2008 6:19 PM
Agree with Czechman. The ethanol blend they make us use is hard on accelerator pump parts.
Everything is different now...
rocker #474735 11/24/2008 2:44 AM
Thanx for your input Czechman, Rocker! Will try that cool
