7 members (Gdads51, TUTS 59, WICruiser, Phak1, Wheelie, Bill Hanlon, 1955 1 Series),
101
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4745 03/02/2005 11:33 PM | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | I'm considering replacing the front leaf springs on my '59 half ton. There's nothing wrong with them, other than they're 45 years old. I''m sure the shackles and bushings are worn, and the ride height has probably dropped due to spring sag.
I've seen comments on this site about re-arcing springs, but I'm wondering, would it be simplier to just replace them? Are reproduction springs any good? I've noticed there are 2 price brackets for reproduction springs (about $266/pair or $370/pair), depending on where you buy them. Any comments would be appreciated. -LT | | |
#4746 03/03/2005 12:32 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I would not replace them unless there is a reason. The bushings shackles are most likely worn and should be replaced, but unless the springs are damaged in some way I'd keep them.
I recently found three broken leafs in one spring on my Suburban. I bought shackles and bushings and then used the springs off a parts truck I already had. Seems to have worked out real well.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | If you have access to a good spring shop, bring in your springs and let them re-arch them. The new springs are not near the same quality as the originals. They will also re-bush or anything else you need done at very reasonable prices.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I had mine re-arched for $100 per axle. New bushings come in the new shackle kits you can get from most any supplier. | | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | Thanks for the advice. I'll look for a spring shop that can rework my springs.
Mr. 4d9r, I see yor are in Menlo Park. I'm just down the road from you. If you have a recommendation for a local spring shop, please let me know.
Thanks, LT | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | LT, I use "AC Spring",I believe that's their name. A real old type spring shop about a block down 13th street, off 101 in San Jose. It's like stepping back in time.... good luck, Terry
