0 members (), 115 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#47383 07/08/2005 2:21 PM
The manual says my transmission has Power Take-Off Provisions on the lefthand side. What is this? Is it like a tractor? Thanks.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#47384 07/08/2005 2:54 PM
a bit like the tractor, but where the tractor can hook up to a variety of equipment w/ 'quick couplers', the 4 spds have a "fixed" PTO option that allows the trucks engine to power auxillary equipment, particularly a dump box on the bigger trucks
#47385 07/08/2005 7:51 PM
The PTO opening is the approximate 4" x 6" steel cover on the side od the transmission. It will have 6 bolts attaching it. The PTO itself is installed onto the side of the tranny where this plate is located and is shifted into and out of gear by either cable or lever. The old ones (40's-50's) were nearly all lever controlled but nowadays the cable is generally used or all that is available for your old tranny. A shaft is attached via a U-joint to the PTO output shaft and it attaches on the opposite end to a winch, pump, sprocket or whatever to operate a piece of power driven equipment, i.e, a dump hoist as red 58 mentioned. However it is also possible to use a quick disconnect shaft on the end of the driven shaft so it is just like a farm tractor. The PTO will have a percent of engine speed ratio from 40%-120% depending on model and type. Direction is important depending on what is being driven.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#47386 07/08/2005 8:28 PM
i have a tranny like this on my 1959 gmc long bed. Does anyone have pics or any way to i.d. my tranny. Also what are they worth if i wanted to sell it.
#47387 07/08/2005 8:42 PM
gmck - likely the usual 47-67 SM420 4 speed you have if it's original - worth whatever you can get for it! check the swapmeet and see what folks are asking or offering - maybe a hundred or 2
