8 members (wvstovebolt, 1955 1 Series, SuperSport, ‘37ChevyPU, tclederman, Gray_Ghost, Cletus1950, 78buckshot),
49
Mod | | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | I currently have a 3 speed on the tree with a 250 c.i. and the 3 speed is getting worn out (leaking, speedometer gear, grinding, and 3rd is not high enough). I was wondering if a T-4 Borg warner will bolt up to my 250, because I found one for a very good price. | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | I think the t-4 has the ford bolt pattern. Like a t-5 out of a mustang. I'm pretty sure you could use a jeep 2.5 to t-4 bellhousing or an aftermarket adapter to bolt it up, but then your "very good price" is sorta moot! Unless you can find the jeep bell on the 'bay or something.
Who is John Galt?
| | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | Well maybe, but this one was out of a S-10 so i was thinking it would be the same, but thanks for the input.
1964 c-10
| | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | And, the seller said he previously had it in his 235 inline, so i guess what my question is, will a tranny that will bolt up to 235 bolt up to a 250?
1964 c-10
| | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | Yes it should bolt right up to your bell housing. Should have a 1 inch 14 spline shaft so you will have to change your clutch disc. Should be the same transmission as a T-5 with out the overdrive gear. You can add the right parts a make a t-5 out of it. I used a T-4 main case to replace a bad one on my T-5 and it all looked the same. Some of the jeep parts web sights offer a converson kit. So just go by the tech tips for installing a T-5. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | T4 is a 4-speed version of the T5. same problems apply. -need to cut the input bearing retainer, extend the splines and cut off the pilot portion, or pull the input shaft and bearing retainer from a camaro V6
| | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | Thank yall, I think i am going to take on this project,it should be interesting since this is my first real transmission work and I am only 17.
1964 c-10
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Did GM use a t-4? The only ones I have seen are from jeeps and I think I saw a fomoco version. I have never heard of a gm pattern t-4. What did they come in originally?
Who is John Galt?
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | sorry, just looked at drivetrain.com and saw they were used in 83-84 camaros and 83-87 s-10's. You learn something everyday. I pulled a saginaw out of an '82 camaro and assumed they went straight to the t-5.
Who is John Galt?
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | I'm not sure this will solve all your problems. You stated that your 3 speed is not high enough. Unless this trans is an overdrive it will not change your final ratio which will still be 1:1. Fred
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | I agree, I'm gonna run a t-5 in mine.
Who is John Galt?
| | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | I realize that, but with a lower first gear I think I will be able to get a higher Rear End Gear.
1964 c-10
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | I doubt that the T-4 has a much lower first gear than the original 3 speed or the T-5. I think you could do the T-5 conversion much cheaper than buying the T-4 and then having to replace the rear end gears. You could also look into the factory overdrive that was available for a 65. Fred
| | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | oh well, I have already bought it. Maybe in the future, if I don't like the T-4 I can look for a T-5. But if nothing else this will be a lerning experience for me. Also, if I do the conversion correctly, I will know what to do and how to do it for next time.
1964 c-10
| | | | | Joined: Nov 2008 Posts: 36 Apprentice | | Apprentice Joined: Nov 2008 Posts: 36 | And I have looked into the "Gear Vendors" which bolts on behind your existing transmission and adds a lo/hi to every gear, but that price is through the roof. I have not been able to find the factory overdrive. Thank yall for all the input and advice.
1964 c-10
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The T4 just lacks the overdrive. You would need to swap out the tailshaft and add the 5th gear. That is the beauty of the T4 / T5 family. kind of like mr potato head
