1 members (klhansen), 158 guests, and 5 robots.
Topics128,089
Posts1,056,141
Members48,436
#47376 07/08/2005 12:57 PM
Junior Member
Junior Member
I have a 61 chevy with a 235 inline and in was wondering how I can switchit from the old canister filters to the spin on type any ideas will help
The only way I know would be to use an aftermarket remote filter unit. These are available from Summit, JEG'S, etc. There is agreat tech tip article on the Inliners site about switching a 235-261 to this. Just do a search on full flow fiter and you'll find it.
www.inliners.org
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Hint: If you do convert the setup hold on to your original parts as you may someday wish to use them again.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
If you convert to a spin-on filter, be sure to use the right one. Your engine probably has a bypass-type filter that has a very slow rate of flow. If you use a full-flow type filter you'll kill your oil pressure. There are a few spin-on filters for bypass systems with a small outlet orfice to maintain oil pressure. I have such a system on a 1961 American Motors Rambler flathead 6-cylinder. A filter such as this would work, as long as you use an adapter with the correct thread. Another option would be to use a return line with a restrictor bushing to control oil flow through a more conventional type of spin-on filter.
1 Offline
i think filters for fords have bypass valves.
i think a full flow oil conversion with a spin-on filter with a bypass value would bt the best setup. but that is not a simple bolt on procedure.
2003 ford lightning
1959 chevy 36
I use an Amsoil bypass with a manifold mount spin on. The unit has a restrictor the size of a pinhole but I get about 1 quart per minute of flow at idle without any significant pressure loss. Here's a few pic's and a link to the Amsoil parts page.
http://client.webshots.com/album/377765249JMMHth
http://www.amsoil.com/bypassfilters/partslist.aspx
Curt B
You Tube
I have a 235 and i removed the original bhive filter assembly and went with a remote oil filter mount from Moroso. I pieced everything together without doing much research. Everything seemed ok until i got the motor running this past weekend and i don't have any oil coming out of the rocker arm assemble on the head. I did hook up an external oil pressure guage and at idle i have about 15lbs of pressure and with increased rpm, i have about 25 to 30 lbs of pressure. Is this the correct amount of pressure? Do i need a restrictor to increase the pressure? Will increased pressure ensure the propper oiling of the top of the motor? Sorry to post all this in this thread but I am a new user and cant find the link to post a new message. All answers are greatly appreciated.
Jackson.
