4 members (52Carl, klhansen, Bill Hanlon, farmallb), 334 guests, and 5 robots.
Topics128,159
Posts1,057,037
Members48,460
I had a valve stick. Pushrod came undone. Ran terrible & was hard for me to find the problem. It's fixed now.
Is there a top oiler or some procedure you can do to prevent sticking valves?
Tab Offline
Yeah, Rislone Try it and let me know. If it keeps happening, convert that sucker to a Wankel ;•S
delete my account and pictures
Tab Offline
V
V Offline
Rislone/Marvel Mystery oil/or just good old ATF.i add some a few miles before an oil change and run it a while then change the oil.
Well if it sticks again I would seriouly look into having a valve job done on the cylinder head. The valve guides are probably worn or you have a bent valve. If it stuck once you need to figure out the "why". Are you getting oil up to the Rocker arms? This is easily checked by running the engine without the valve cover on. If you have oil to the top Good. If you don't you need to get that fixed first and then go from there.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
