| | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47371 07/08/2005 2:04 AM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | I had a valve stick. Pushrod came undone. Ran terrible & was hard for me to find the problem. It's fixed now.
Is there a top oiler or some procedure you can do to prevent sticking valves? | | |
#47372 07/08/2005 2:12 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Yeah, Rislone Try it and let me know. If it keeps happening, convert that sucker to a Wankel ;•S
delete my account and pictures
#47373 07/08/2005 2:14 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 |
#47374 07/08/2005 11:17 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Rislone/Marvel Mystery oil/or just good old ATF.i add some a few miles before an oil change and run it a while then change the oil. | | |
#47375 07/10/2005 3:32 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Well if it sticks again I would seriouly look into having a valve job done on the cylinder head. The valve guides are probably worn or you have a bent valve. If it stuck once you need to figure out the "why". Are you getting oil up to the Rocker arms? This is easily checked by running the engine without the valve cover on. If you have oil to the top Good. If you don't you need to get that fixed first and then go from there.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
