0 members (), 128 guests, and 0 robots.
Topics128,035
Posts1,055,560
#4734 12/09/2002 4:12 AM
Junior Member
Junior Member
Okay, I've wound up with a couple of pressure plates off of some large truck, and I'm trying to figure out what they go to. At least one is a new unit. The tag on it is Lipe Corperation, model 330-16 1928. The clutch disc is 13" overall, with a 7.25" ID on the facing. It has a 10 spline, 1.5" center. The pressure plate has 12 mounting holes, on both 14.25", and 14.75" bolt circles (there are 2 complete set of holes) The throwout I have on one uses an adjusting nut on the shaft connecting it to the pressure plate, and it has 2 pegs on the sides, so it looks like it uses a rotating fork, not the pivioting kind. I was thinking that it might be for a later 60's 2-2.5 ton chevy diesel, but I'm not sure. Anyone have any ideas? Does anyone have any idea where I could look up the lipe number? I'm told they're not in buisness anymore, but there should still be references to them somewhere. I've also heard that it may be for a tractor, what do you guys think. Any help would be greatly apreciated.
61 chevy c40 w/ holmes 400 wrecker bed. 350, 4spd, big window.
61 chevy c40 flatbed, rebuilt 327, 4spd, custom 12' flatbed. (for sale)
85 **** f250 diesel, c6, 3.31 rears
#4735 12/10/2002 4:18 PM
Hey amigos, don't let this dude's actual TRUCK QUESTION get overlooked (I don't know enuf to help him).
respectfully,
ed b.
#4736 12/11/2002 2:21 AM
hello bigjohn83. i had gone to a local auto parts store,[this supplier has a complete line and is not limited like some of the national chains are], and they were able to identify clutch discs by the dimensions.if you have a store near you that supplies commercial fleets, they might be able to i.d. your discs by using the dimensions. hope this helps. good luck.
our garage is a non-profit organization
#4737 12/11/2002 8:19 PM
Junior Member
Junior Member
Any ideas where?? Do yall think napa would be able to do it? Thanks for the info.
#4738 12/13/2002 1:34 AM
Junior Member
Junior Member
Okay, I called a big clutch place in sacramento today, and all they could say is that it's a pretty much generic 13" clutch, but he said that it should fit 50-60 gm mediumm duty trucks, so I guess I was actually right. Anyone need a new clutch??
