4 members (UtahYork, cmayna, Otto Skorzeny, Bucker), 111 guests, and 0 robots.
Topics128,162
Posts1,056,916
Members48,458
I might like to try making my own bed wood. Anyone done this? how thick? I have seen mar-k's diagram of the grooving, but don't remember seeing the thickness. Does it matter? Could you increase, say from 7/8" to 1 " or would it raise your bed? any hints are appreciated.
Who is John Galt?
Sorry I just checked Mar-k again and found the thickness, 25/32". I am not sure how to attain this thickness, or how critical it is. I guess I could ask the lumber yard to plane it by 7/32". I have a router to make the grooves. Also, are all wood beds 25/32"? My '62 is the same as a '36 or a '54 or whatever else?
Who is John Galt?
Check the height of the lip on the rear cross member (where the wood will sit). This is right at the tailgate.
I think you will find that it's 3/4". Any thicker than that and your wood will stick above the edge of your cross rail. It won't hurt anything but dosen't look too good.
Hope this helps
George
Also, the wood needs to slip under the flange on the bedsides.
The thickness should be even a little less than 3/4"
Like AD says, it has to fit under the side angle strips without having to force it in.
Originally Posted by neilroy
Thanks neilroy! That's answered a few of my questions too!
Jock thumbs_up
More pix on Flickr.
I'll vouch for those instructions.I took them to a local place and had my choice of wood machined to size for $100.00 and the fit was perfect in my case. I went with ash:
http://good-times.webshots.com/photo/2789166150023244788foEoOw
You Tube
I used some 3/4" dressed Oak, sanded a little to remove planer marks. Used a table saw to groove the edges, and a forstner bit to recess the off-set washers. Worked great.
1940 Chevy KC 1/2-Ton
I just purchased a Red Oak kit for mine grooved and milled to thickness for $302 (shiiping included) from American Classic Trucks Bedwood on Ebay. I can't touch it for that at the local yards here in Utah. I looked/called a few and they want around $7 a foot. By the time you buy the boards (raw) it is well over $400. Is it that high in the rest of the country or just a local condition out west?
i have a lumber mill so i used good old d. fir
