3 members (Bills54, mo2cyl, HandyAndy), 77 guests, and 3 robots.
Topics128,047
Posts1,055,534
Members48,424
#473338 11/20/2008 5:27 PM
What is the best way to remove/install stake pockets? They have those same internal spot welds as the angle strips in the bed. I ground out the angle strips since I sandblasted the entire bed, but really don't want to grind off the stake pockets.
Use a spotweld cutter. Eastwood has a good selection.
Steve
'49 3800
'52 3600
'57 3100
As Ghostrider said, a spotweld cutter is probably the least aggressive way to do this. It simply cuts through the first layer of metal/weld and preserves the one underneath.
That's provided you use it sparingly!
Centre punch each spot weld first and go easy!
Hey...If I can do it, you can. thumbs_up
Jock.
More pix on Flickr.
