As Ghostrider said, a spotweld cutter is probably the least aggressive way to do this. It simply cuts through the first layer of metal/weld and preserves the one underneath.
That's provided you use it sparingly!
Centre punch each spot weld first and go easy!
Hey...If
I can do it, you can.
Jock.
