0 members (),
140
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Had some help from a good friend and changed my headliner. Now it matches the seat material and has the same “stitch” design as the them as well. It wasn’t nearly as hard as I thought and only cost about $60.00. We used 3/16” plywood, dense foam, some 3M 08088 glue and fabric. I shoved a piece of cardboard in the slot, drew a line on it around the hole and then cut it for a template to cut the plywood. When you have the plywood base right, you spray glue on the wood and the foam separately and let them set for about 5 to 8 minutes – once you touch them together, they are stuck so make sure you place them where they need to be. The next step is to cut the lines in the foam. Using a straight edge, draw the lines in the foam. Then move the straight edge about 1/16” to 1/8” past each side of your line and cut a “V” in the foam down to the wood and peel the pieces out. Now you lay the fabric over the foam. Pull ½ of it back and spray both the foam and fabric with glue. After it sets for the 5 to 8 minutes, ease the fabric over to the first cut line. When you hit it, we used a wooden dowel to push the fabric into the V, smooth it on to the next V and repeat. When that’s done, fold the other ½ back, spray glue, wait, and repeat. That’s the cliff notes for doing this job. It may not be perfect, but I’m very happy with it – especially for a first time. http://img.photobucket.com/albums/v228/Avette4me/My%2058/before%20and%20after/Headliner1.jpghttp://img.photobucket.com/albums/v228/Avette4me/My%2058/before%20and%20after/headliner2.jpg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That looks great, vette. That molding you have on there looks better than a rubber seal. What is that? | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | It's a press/tap on trim. It has little metal strips inside to provide a good grip and you can cut it to make a good seam. I bought it from a local upholsterer but I think it's available in a lot of other places.
I've used versions of it in the trailer industry as well. They call it fender trim.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Try this Cletis, Canadian company and probably only wholesale but they may have stocking dealers in the states, let us know if you find any dealers. http://www.trimco.info/index.html Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | That's a good link Denny.
I have to test mine a little, but there's a possibility that I'll need a lip to hold the headliner better. If so, I'll check them out and let you know.
By the way cletis - I still have a little piece of it. If you would like a sample, let me know....
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Great Job Vette!...looks really profesional. Tim | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | lonny do you have a shared photobucket?? i saw the 3 nice pics...... i can't seem to get to see it ....
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you have photobucket which has public viewing, see album settings or maybe you don't that's ok too
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | could you still not open it? | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | carolines truck, what are you trying to say??? Duh!! | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | carolines truck, what are you trying to say??? Duh!! Are we being pissy and I didn't get it? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | WOE NELLY ... hold your shotguns boys .... OK ''you have photobucket which has public viewing, see album settings or maybe you don't that's ok too'' I stated here that maybe you don't want others to see your pictures.. it's about sharing. all i wanted to do was look at more pictures of what avette4me might have on his photobucket shots. I have a shared photobucket ( http://s67.photobucket.com/albums/h298/1951otter/ ) and avette4me only had links to three of his shots. i'm about to do my interior and just wanted to see what other nice work was done and maybe get some ideas B4 my big indevor. photobucket allows other none password folks to see photos in your photobucket pictures, but the site owner, (in this case avette4me) has to set it up to allow for public viewing. .............. '' see album settings '' in his, avette4me's site. OK It's not a big deal forget i mentioned it. that's what i'm trying to say and did. i'll not bother either of you two guys again. c-ya
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | all i wanted to do was look at more pictures of what avette4me might have on his photobucket shots. I have a shared photobucket ( http://s67.photobucket.com/albums/h298/1951otter/ ) and avette4me only had links to three of his shots. i'm about to do my interior and just wanted to see what other nice work was done and maybe get some ideas B4 my big indevor. photobucket allows other none password folks to see photos in your photobucket pictures, but the site owner, (in this case avette4me) has to set it up to allow for public viewing. .............. Sorry for the misunderstanding. I went back and looked for a setting to make my truck and vette stuff public, but can't find it for single albums. Maybe you can help with that - if so, I'd sincerely appreciate it. There might accidently be some pics that could help someone. Otherwise, I keep it private only because I store a lot of family stuff (home, kids, grandkids, etc.) there and really don't want some internet perv jacking with it.
