2 members (jmoore, 68ironhead),
86
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | I thought I was being smart by removing a couple of door scuffs on my truck with a green scracher and some water. Good news is it worked very well but it left scratches and dullness in the paint. I've tried a couple of the different scratch removal products and even tried my buffer. What else can I do? | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | I would recomend wet sanding with ultra fine sandpaper like a 2000 or finer grit and polishing with a medium rubbing compound,preferably machine polishing. Once you eliminate the scratches,move to a finer polish,and finish with a good glaze like Meguiers. Depending on the color of the paint(use extreme caution when sandin metallic colors)you should be able to make it look like new. | | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | If your first effort is unsuccessful, ask Len at autobodystore.com He is very much a paint/restoration expert, and the great thing is he is like the guys here, he wants to help! Good luck. Scott | | |
