6 members (pdlightning, tesa, baldeagle, walter74, Jman, 1 invisible), 324 guests, and 4 robots.
Topics128,166
Posts1,057,092
Members48,463
I am looking for info. on 1932-40 Chevy pickup and car axles. I'm sure there is a Chevy book that shows measurements and year change. I know some axles have a bend in the middle, some have a hole by the U-bolts for a shock and some are narrower. I am now starting to drop the earlier axle and you guys on the Stove Bolt have been great help. Thanks
Thanks! That page is great Joe. A lot of info. Helps me on the 37-40 stuff. I still need to find the info on the 1932-36 axles now. Thanks SID
HI;
28-32 the axels will bolt in, 28-29 have brake rods there are levers to operate the front brakes on the axel, they can be easly removed, 30-32 have cable operated front brakes , I have a 29 Chevy and a 30 Chevy truck the 29 been in my family since new I've also collected about 18 28-31 parts cars and trucks over the years ,feel free to ask me question on these old Chevys, BILL
Sid, as far as I know the 41-54 front axles are a bolt in change for the 30?- 40 front axles.
I got a dropped axle from you on ebay to put in my 1940 gmc. The advantage for me was the larger king pins, and the ability to bolt on the cpp disc brake kit.
I haven't mounted it in the chassis yet, but I am absolutely certain I won't have any issues with it. The axle looks great.
Keep up the good work.
Thanks I have the info on the 41-54 axles. There are some differences on the 41-54. Bigger kigpins (8.66 dia.) the 41-47 does not have a relief cut to get a socket on the U-bolt nuts but are the same as the 48-54 other then that . I drop axles and have customers wanting them to fit a 30's car. When I use the 41-54 I have to narrow them sometimes during the drop to make them the right width as the original for some early chevys. What I am needing is the info on changes for each year. That way if a guy wants a original 32 axle just like in his car I give him the right axle. I have a guy in New Zealand that wants a original 32 axle dropped. I'm not sure what that exact year looks like. I know one time I had a chevy axle that was bent back in the center like to clear a oil pan. Not for sure what year it was. I also know some years have a extra hole in the spring pad for the shock to mount to and some don't. I do want to Thank everyone for there help. It does help Thanks SID
The 30-33 have the extra hole for the shock mount ,I don't know what axle had the bend in the middle,BILL
