4 members (Bucker, Nick in Manitou, Shaffer's1950, 1 invisible), 220 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#47308 07/06/2005 12:43 PM
Junior Member
Junior Member
I wanted to put some insulation on the engine side of my firewall. I have some stuff rated for it, foil on both sides works pretty good. Only problem is that the metal tape I tried to use to get it to adhere to the wall doesnt work too well. What should I be using to adhere the insulation to the inside of my firewall?
#47309 07/06/2005 2:59 PM
spray on contact cement or roofing tar, but don't expect that stuff to stand up to real vehicle use for an extended period - not dangerous, but it does deteriorate over time w/ exposure to heat, water and physical bumping/scrapeing
#47310 07/06/2005 9:30 PM
What year is your truck? Check with the local body shop/paint supplier they should have all kinds of retainers for this type of application.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
