0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47308 07/06/2005 12:43 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | I wanted to put some insulation on the engine side of my firewall. I have some stuff rated for it, foil on both sides works pretty good. Only problem is that the metal tape I tried to use to get it to adhere to the wall doesnt work too well. What should I be using to adhere the insulation to the inside of my firewall? | | |
#47309 07/06/2005 2:59 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | spray on contact cement or roofing tar, but don't expect that stuff to stand up to real vehicle use for an extended period - not dangerous, but it does deteriorate over time w/ exposure to heat, water and physical bumping/scrapeing
Bill | | |
#47310 07/06/2005 9:30 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | What year is your truck? Check with the local body shop/paint supplier they should have all kinds of retainers for this type of application.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
