5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#472897 11/19/2008 5:48 AM
I have a 66 c10 with a 283 I just acquired the truck. the truck ran in the driveway after unloading off the transport. pulled it into the garage and now wont start. It will run as long as I keep pouring gas into the carb. I unscrewed the line at the carb from the fuel pump and turned the engine over nice big blast of gas. I guess I have narrowed it to the carb but this is where i need help. I know nothing about carbs. Why is the carb fuel starved? Does it need totally rebuilt? thank you so much for the advice. Chris
chris0151 #472963 11/19/2008 2:32 PM
Carburetion specialist
From your description, I would guess that either the float is stuck in the closed position or the fuel valve is stuck in the closed position. This is quite common with a vehicle that has sat unused for some time and modern fuel. When modern fuel evaporates, it leaves a gummy goo that glues things together. Disassembly, a good cleaning, and reassembly with a new rebuilding kit should correct the issue.
Jon.
The Carburetor Shop
carbking #472968 11/19/2008 2:48 PM
Carb's are not as scary as you may think.Get another old one from a scrapyard or friend.Dosen't even have to be the exact same type.Take it apart slowly,see how it work's.Now get a kit for your's and go through it.Tom
grub #473070 11/19/2008 10:22 PM
Riding in the Passing Lane
It probably has a rochester 2 barrel carb. That carb has a filter in the inlet. Get a 1 in. wrench & hold the fiting & remove the tube. Remove the fitting & it should have a small filter behind it. It may be plugged up.
1972 Chevy c10 Cheyenne Super
Thank you all for your advice. I am planning to overhaul the carb and see if that will cure most of the problems. It is a rochester 2bbl.
chris0151 #474348 11/23/2008 1:40 AM
It really doesn't take long with modern gas to gum up, either, especially if it is in a vented tank. I last used my rototiller in July. I had put fresh gas in it then, but when I tried to start it up last weekend I found that it wouldn't start. I found little balls of goo in the carb. Some fresh gas and a quick clean-out of the jets and she's running again.
Paint & Body Shop moderator
