8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY), 126 guests, and 1 robot.
Topics128,109
Posts1,056,253
Members48,437
It's been awhile but a new Work-in-Progress log entry "Summer of My Discontent" has been posted. I've been lazy and hazy since the last BillyBob log entry and I haven't gotten much done. This episode deals mostly with replacing a rear main seal for the first time. Yeah, I'm gonna hafta do it again!
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
You don't have to do it again. Catch all the drips in a coffee can(I prefer Folgers) and pour back in the motor. Repeat as needed. I'm out of beer. Gotta go.
Drew
LAROKE,
FYI stainless bolts do not spall they gall. Concrete and bricks spall. how to keep stainless bolts from galling
Thanx fellas and thanx for the link, Lonnie. I should have known better. I was an architect and practicing artichokes know (or should know) the basics of all three of those materials.
Larry Kephart
Boca Raton, Florida
I don't know about using a neoprene seal in a 54 but because your motor has shims, you have the opportunity to adjust the main bearings. If you are able to snug them up some, you will have a much better chance of stopping the leak.
1951 1 Ton Completed
I have a rear main leak on my 350 that has been to a repair shop twice. Still leaks like rain. Clutch now chatters from all the oil.
Little off track here but everyone using SS. Bolts If you happen to get one that galls on you just mix a little lite oil and valve grinding compound to loosen it up. Just squirt some on the bolt threads or arounfd the bolt and let it soak in down around the threads for a few minutes. You then can then move it back in forth most of the time. It may be only a little bit at first but keep putting the oil mixture around the bolt evenually the bolt will come free. We have used this method a lot of times around food machinery. Believe me it beats having to drill and retap a hole in the equipment.
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
