| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Alright, I finally got myself a Uni-Syn carb syncronizer (got a good deal from the Matco dealer), and I think I have a grasp on how to use it. However, if anyone has any good tips on how to use it to get the best results, I would greatly appreciate it. TIA
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The cone-shaped restrictor in the air horn section is screwed down until the floating indicator rises to about midrange of its travel on one carb, then it's transferred to the other one(s) and the idle speed and screw is adjusted for the same amount of air flow. The see-through tube with the floating ball in it needs to be straight up vertical for the best results. Adjusting the idle mixture screws should have little, if any effect on the air volume, but if it's necessary to make a big change in mixture, double-check the air flow. Jerry
| | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I synchronized the duals SU carbs in an Austin Healy Sprite with an original UniSyn, but didn't trust the results. Bad mistake. I took it to a Healy dealer and had them adjust them. It took about 300 miles for the two rear exhaust valves to burn up. Sodium filled valves $60 each in 1972 dollars.
Have a little faith in yourself when you use a Uni-Syn. It's really pretty easy to see what's going on.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Depending on the condition of the carb throats,a little vaseline, don't glop it ,on the rubber seal can help. Then just wipe it clean.
Drew
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Make sure you loosen the linkage between the carbs before you try to adjust the flow or you will adjust one and the other will be off again. Dont forget to tighten the linkage back when you are finished. Would want you to go off half carbed.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Has anyone ever used two Uni-Syn's, one on each carb, with any good results? Would that make the job easier? Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Joe, The Uni-sync is adjustable so if you could set them the same, you wouldn't need them, just set the carbs the same! The uni-sync has a movable stopper that plugs the inlet hole and creates a slight vacuum. The vacuum pulls the small indicator ball up a tube with a scale on it. The idea is to adjust the gauge so the ball is midway up the tube, then move to a second carb. With out adjusting the gauge, set the idle speed till the second carb is pulling the same amount of vacuum on the tube. Once both are set for the same vacuum, you know the throttle blades are open the same amount, now its a matter of jumping back and forth to set the idle speed. Each adjustment of the throttle blade will require a uni-sync check of all the carbs.
Joe | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Joe I did use 3 unisyncs on a 54 corvette a few years ago. Had to borrow 2. But I was looking for some trickey acceloration problem that had me baffeled. I thought 2 carbs were pulling more than the other on acceloration. http://rides.webshots.com/photo/2326100990093759043wLJqQR But as a normal adjustment process it is just over kill.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | I'm not sure, but I think the unisyn needs to be the same one on both carbs! I think that the unisyn is measuring the carb its on, and placing it on the other carb enables you to duplicate it's airflow/vacuum. Using two would give you a benchmark for the other! What I'm saying is sticking to one removes a variable, and is the intended means of EQUALIZING the carb settings. I have yet to use it on my 261 dual carb, but used one on a motorcyle years ago, so I may be remembering wrong ( insert grain of salt here.)
Who is John Galt?
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | You are correct blackjack. You set up the meter on one carb and then match it to the other. When i used 3 unsync units i took all three and set them up on #1 carb. then taped (duck tape) the units to the 3 carbs.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | I wouldn't have thought of that, setting three using one carb! It would make it easyer to set all three at once. Joe | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Joe I was checking for a differance in carb. opperation under acceloration not setting idle flow. The carbs were in sync. at idle. As it turned out they were all pulling the same on acceloration also. My problem was timing advance and fuel. We found that if you mix premium unlead and aviation (110 octain) fuel together it ran 200% better.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yep, the problem with using more than one Uni-Syn is that each of the two or three you use would have to be set exactly the same to match the other two or or three. Therein lays the problem. I don't see anyway that you would know that each Uni-Syn you used matched the sttings of the others. I never thought of it in those terms. Duh! Joe
