8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47238 07/04/2005 3:36 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | I have a saginaw 4 speed with the 3.11 first gear and a 3 speed overdrive transmission. Now the question. Can I remove the tail shaft from the OD trans. and put it on the 4 speed? Is this feasible? It looks as if it the bolt pattern is the same. Has anyone done this? What machining is nessary if any? I thought I would seek knowledge before I rip into it. Is there any out there? | | |
#47239 07/04/2005 6:27 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Go to the chevytrucks.org web site for step by step instructions on how to do this | | |
#47240 07/04/2005 6:45 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | 4.3in84toy Thanks for the info. but they are talking automatic trans. I am working with manual trans. | | |
#47241 07/04/2005 7:10 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I did this back in the 70's. It was pretty straight forward. You need to weld a tab on the reverse shift lever to lock the OD out when in reverse.
Once you have the OD on the 4-speed you'll have to make your own shifter rods. You can't just order the Saginaw shifter from Patricks as expect it to work out of the box.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#47242 07/04/2005 9:05 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Do a search of the archives here for this topic that comes up about every 6 months and it will point you to the chevytrucks.org Here is the link to the chevytrucks.org site and follow the instructions, pictures and everything. saginaw 4 speed overdrive link I believe there is also a link or tech discussion on this at the inliners site. This is a pretty common thing to do. | | |
#47243 07/04/2005 11:24 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Tony or "truckedup", #107, here on the Stovebolt built one up recently and posted pictures.
'67 GMC 3/4 292 4spd
#47244 07/05/2005 12:49 AM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Thanks guys for all the information. I knew the BRAINS were out there. Tom | | |
