3 members (Bills54, mo2cyl, HandyAndy), 77 guests, and 3 robots.
Topics128,047
Posts1,055,534
Members48,424
#47238 07/04/2005 3:36 PM
2 Offline
I have a saginaw 4 speed with the 3.11 first gear and a 3 speed overdrive transmission. Now the question. Can I remove the tail shaft from the OD trans. and put it on the 4 speed?
Is this feasible? It looks as if it the bolt pattern is the same.
Has anyone done this?
What machining is nessary if any?
I thought I would seek knowledge before I rip into it. Is there any out there?
#47239 07/04/2005 6:27 PM
Go to the chevytrucks.org web site for step by step instructions on how to do this
#47240 07/04/2005 6:45 PM
2 Offline
4.3in84toy Thanks for the info. but they are talking automatic trans. I am working with manual trans.
#47241 07/04/2005 7:10 PM
I did this back in the 70's. It was pretty straight forward. You need to weld a tab on the reverse shift lever to lock the OD out when in reverse.
Once you have the OD on the 4-speed you'll have to make your own shifter rods. You can't just order the Saginaw shifter from Patricks as expect it to work out of the box.
#47242 07/04/2005 9:05 PM
Do a search of the archives here for this topic that comes up about every 6 months and it will point you to the chevytrucks.org
Here is the link to the chevytrucks.org site and follow the instructions, pictures and everything.
saginaw 4 speed overdrive link
I believe there is also a link or tech discussion on this at the inliners site. This is a pretty common thing to do.
#47243 07/04/2005 11:24 PM
Tony or "truckedup", #107, here on the Stovebolt built one up recently and posted pictures.
'67 GMC 3/4 292 4spd
#47244 07/05/2005 12:49 AM
2 Offline
Thanks guys for all the information. I knew the BRAINS were out there.
Tom
