| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47234 07/04/2005 2:15 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | Any one out there change steering wheel's on their AD truck? Thinking of going to a smaller dia, maybe 15" dia,flat dished,I don't think it will effect steering much.My truck steers real easy with everything rebuilt ,I would like a smaller wheel. what type of wheel has anyone used?old navy 51.............. | | |
#47235 07/04/2005 2:25 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I bought a Grant from Chevy Duty, It's about 15"-15 1/2" wheel..Not flat dished, but not deep either..Went on well, but taking the 54 wheel off wasn't a thrill..Even with a wheel puller, it took a lot of PB Blaster and time to get the wheel off the spline..Best bet is to take your time, spray a little, tighten the puller a little, take a break, and repeat process until it pops loose..My truck actually steers better with the new wheel..I also put on a front sway bar, and new Monroe gas shocks..Steve | | |
#47236 07/04/2005 3:17 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | Thanks Shooper, I also put on a sway bar and monroe shocks ,Ive had the wheel off a couple of times already, so no problem there . any problems making the horn work with the new wheel ? thanks for your help. old navy 51................ | | |
#47237 07/04/2005 3:28 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Horn works just fine, easy to install new stuff..Just remember to disconnect the battery..Later, Steve | | |
