7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | Hey guys where might a guy come up with these? I've been trying to find them but no luck. any info would be helpful. How about wing windows too, I'm missing the glass out of the drivers door. Thanks, Jocko | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | side window parts .... and vent window parts are available from most vendors ... glass alone can be supplied by any local auto glass shop Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Jocko, you've got to use the net brother. It's all there, Steele rubber, Jim Carter, Brothers, Classic parts of America, LMC, Grumpy's and others have your parts. The nicest thing I did was solid windows, no sliders. See my 56GMC (click on the blue signature below). If you are staying totally stock you may not want this. But they are "easy" to do and don't leak. I did mine myself: rubber $100, glass $350. 2008 prices. Rebuilding the sliders is a whole lot of work, done that also and the frames are most always rusted and need repair. Solid windows = no frames needed. Bartamos.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | Thanks Bartamos. I've beeen thinking about solid windows. I thought it would be real cool if you could hingr them the newer minivans and or expiditions. Do you have AC? I was wondering about it getting too hot for the youngins', your thoughts please. I'll check out those sites in the mean time. Your GMC is very simila too my chevy burb. I too have a 454 and a newer running gear. My plan is to do a rat rod job on it with the little distinct custom stuff down to the flat paint job. I'm thinking of doing a very light aqua and white combo fromHot Rod Flatz paints. Anyways, Thanks Jocko | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't have the air installed yet. Air flow is hampered with solid. But so are leaks and rot-out. Rubber kits are more $ too for sliders. How long/bad is a Nebraska summer? 9mo at 105-115 deg is what we have. If your kids are real young you maybe want sliders or tip out. Good luck and let us know with pics what you do.
