2 members (baldeagle, MickeyP), 101 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#47201 07/04/2005 4:17 AM
Happy 4th everyone,
I have a buddy who has a line on a 2series 55 half ton.He is only interested in the body.So we are planning on splitting the cost and i get the drivetrain.My question is -is this rear end higher geard than my stock torktube on my 53 1/2 ton? and how would it work with a 235 and a saginaw 3.11-2 groove? thanks for your input
Aaron
#47202 07/05/2005 5:28 AM
I don't know what the gears are in the '53 but the '55 will have 3:90 gears.
They say the 2 groove signaw is the way to go but with a 1-1 fourth gear it wont help with freeway speeds with the 3:90 gears.
If you do a lot of freeway speed driving you may want to look at the 3:38 ring and pinion kits for the '55 rear end.
#47203 07/05/2005 9:26 AM
The stock gear ratio on the '53 half ton,I believe,is a 4.10,so the '55 would be an improvement. Of course,I always recommend switching to 235/85R-16's if you don't already have 'em.going from a 235/75-15 th the 16's will give you about 10 to 15 more mph (depending on the brand)at the same rpm's.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
