Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, cmayna), 78 guests, and 2 robots.
Topics128,005
Posts1,055,264
Members48,418
#471645 11/15/2008 7:42 AM
someone will know i have a 1952 im at the door windows i got felt on line it was way to wide figured its for the doors with metal frame around the window anyway as the felt goes down in the door what holds it in place half way down the door theres two bolts do they attach to the felt some way what keeps the window from floping around when its down thanks for any help or pictures or drawing mayby thanks!!!
32fire #471661 11/15/2008 12:08 PM
mayby you have the wrong felt how did the old parts come out are you missing screws mayby a shop manual would help it would have a diagram so you could see how it goes
excellant_62 #471691 11/15/2008 3:01 PM
sounds like you are missing screws, and definitely puncuation.
32,
the leading edge of your glass is captured in the channel attached to the vent window frame.
there is a guide channel bolted to the trailing edge of the inside of the door with small screws you can see below your door latch on the outside (there are 4 of them on my 52), you need to remove that channel and the new felt strip gets riveted through its center to that strip all the way down to the end,I also used 3M black weatherstrip cement behind the new felt & let it dry overnight,install the guide in the door then form the new felt around the window frame again using the 3M glue roll up the window and let it cure overnight, next day roll down the window and drill and rivet through the center of the felt to secure it and you have it.
Tim
1952 Chevy Shortbed
Photos in Photobucket
grin grin
Maybe you should check your spelling? wink
Tim sounds right on the money though!
Jock thumbs_up
More pix on Flickr.
SW_Radial #472008 11/16/2008 8:37 AM
wow thanks for the help this part is missing in all 8 doors i looked at its called door glass channel guides i found only one place to get them after looking at the door area of this wonderful site once i get them im on my home streatch of having my truck finished yes finishet and done this truck was my practese truck my next one is a 49 halfton all hot rodded but i really wanted to get to know the trucks before i jumped into it.
32fire #472009 11/16/2008 8:38 AM
oh yes my spelling it does need help
32fire #472011 11/16/2008 8:43 AM
yes i think Tim has worked on the doors i put them off till last thing but they wernt bad i couldnt believe how easy the wind shield went in 10 minutes tops
32fire #472012 11/16/2008 8:49 AM
32fire... I wasn't having a go at you! grin
Oldcar had picked up on your punctuation and I noticed a spelling mistake on his post!
People in glass houses....huh! (pun intended) wink grin
More pix on Flickr.
jockbolter50 #472013 11/16/2008 9:21 AM
32,
Yes I spent many INTIMATE HRS.. with my doors layin on the saw horses..the felt was the easy part ..fitting a set of 1975 caddillac power window drivers was the FUN part!...lol
but NOW I have power windows an they WORK!...they drove me nuts for a month fittin an cuttin ..THEN MORE FITTIN AN CUTTIN ...but it was worth it~!
They work SMOOOOTH ..an slick.
Tim
1952 Chevy Shortbed
SW_Radial #472067 11/16/2008 3:08 PM
Appears that my *punctuation* needs help too! ooops!
Yup! grin grin
More pix on Flickr.
