1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#471783 11/15/2008 8:49 PM
I have a 1947 Chevy COE and of course it has big drum brakes all around. I was wondering if I purchased the power brake conversion system from Bowtie that has the corvette master and booster on it, could I then eliminate the HYDRA UNIT that is on the side frame rail of the truck? Thanks in advance for any help, Roy
3B Offline
Hy Roy Esslinger, yes adapting that setup would allow you to eliminate the hydrovac, I've never done this conversion on a cabover, there may be special clearance issues, hope that helps.
3B #471851 11/15/2008 11:40 PM
I am so glad you told me that. I know the hydravac unit is a good one but I really didnt want to use it. It looks like there wont be any problems with clearance either. BowTie claims theirs is a complete bolt on application with the exception of re-routing a few lines. Thanks so much for your help.
What size of master cylinder works best with the ton and a half dumptrucks? I'm looking at doing something similar....
GMC: Get More Cash...
1958 GMC
My Webshots photos
I agree, that sounds like a good plan.
But be sure you use a large enough master cylinder. Whatever the bore of the stock one is is about what you want for the new replacement. I fear that the ones sold with the kit won't be big enough.
Not entirely relevant, as I have large disc brakes on my truck, but my system needed a 1.625" bore MC, a good bit larger than what would have come in a "kit" designed for the smaller trucks.
Do some checking and measuring first.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
1 Offline
caveat emptor! only thing that bolts on for 100% sure is a wheel! i would ask them for some customer references that have actually used the product. i do this all the time and believe me it has save my [censored] a time or two. just remember the saying "only fools rush in!"
