0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | someone will know i have a 1952 im at the door windows i got felt on line it was way to wide figured its for the doors with metal frame around the window anyway as the felt goes down in the door what holds it in place half way down the door theres two bolts do they attach to the felt some way what keeps the window from floping around when its down thanks for any help or pictures or drawing mayby thanks!!! | | | | | Joined: Oct 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 88 | mayby you have the wrong felt how did the old parts come out are you missing screws mayby a shop manual would help it would have a diagram so you could see how it goes | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | sounds like you are missing screws, and definitely puncuation. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | 32, the leading edge of your glass is captured in the channel attached to the vent window frame. there is a guide channel bolted to the trailing edge of the inside of the door with small screws you can see below your door latch on the outside (there are 4 of them on my 52), you need to remove that channel and the new felt strip gets riveted through its center to that strip all the way down to the end,I also used 3M black weatherstrip cement behind the new felt & let it dry overnight,install the guide in the door then form the new felt around the window frame again using the 3M glue roll up the window and let it cure overnight, next day roll down the window and drill and rivet through the center of the felt to secure it and you have it. Tim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | sounds like you are missing screws, and definitely puncuation.  Maybe you should check your spelling?  Tim sounds right on the money though! Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | wow thanks for the help this part is missing in all 8 doors i looked at its called door glass channel guides i found only one place to get them after looking at the door area of this wonderful site once i get them im on my home streatch of having my truck finished yes finishet and done this truck was my practese truck my next one is a 49 halfton all hot rodded but i really wanted to get to know the trucks before i jumped into it. | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | oh yes my spelling it does need help | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | yes i think Tim has worked on the doors i put them off till last thing but they wernt bad i couldnt believe how easy the wind shield went in 10 minutes tops | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 32fire... I wasn't having a go at you! Oldcar had picked up on your punctuation and I noticed a spelling mistake on his post! People in glass houses....huh! (pun intended)
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | 32, Yes I spent many INTIMATE HRS.. with my doors layin on the saw horses..the felt was the easy part ..fitting a set of 1975 caddillac power window drivers was the FUN part!...lol but NOW I have power windows an they WORK!...they drove me nuts for a month fittin an cuttin ..THEN MORE FITTIN AN CUTTIN ...but it was worth it~! They work SMOOOOTH ..an slick. Tim
| | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Appears that my *punctuation* needs help too! ooops! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Appears that my *punctuation* needs help too! ooops! Yup!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
